Avatar_41, I am not sure what is your expectation. I think JesperMP has pointed out to the best resources from Siemens. Maybe you could use some translation add-ins for your browser. If you want to learn and do a good program this is of course good.
But if you are in urgent need of bringing the system back to working order, and since we have at least preliminarily concluded that there may be some problem with the remote IO device (becasue the SF or system failure lamp is on, and so on), I suggest you power this device off, check the Profibus connector's screws, make sure they are tight, check the wiring for the IO and if possible disassembly the remote IO, see if there may be a contact problem in the backplane connectors, put it all back and see what happens. It may be something relatively to fix if the module is not damaged.
