Cimplicity
Apr 2004
India
Tell me please about CIMPLICITY
I have 16 Ge fanuc Versamaxmicro on all my Boiler Water lancher system
and going to be view remotly from CR. Is it enough to buy Cimplicity?
.And will it be able to modified the ladder from remote using GE fanuc Cimplicity only?
BR.
Cimplicity:
1. It is a generic term used for software sold by GE Fanuc. There are a couple dozen varieties so make sure that you research the right one. Contact your local distributor for a demo CD.
2. Cim. Machine Edition can be used to collect data and program the PLC.
3. Cim. Plant Edition is used to collect data, web server, HMI, etc.
There are many similarities to the two when collecting data, PE is much more powerful in this area. Either can connect to a network of Micro PLCs through the SNP multi-drop or add the Serial-to-Ethernet device and use your local lan. Go to www.gefanuc.com for detailed information.
194
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
188
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
226
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
129
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
165
