CIMREX 41 PROGRAM UPLOAD
karthikbm
Mar 2024
tamilnadu
in our old machine we used beijer cimrex 41 need to take program backup. i tried it with information designer software through ethernet. ip address also pinging but not able to take backup.is there any other solution.
Hello Everyone, I'm working on a couple of systems that use Beijer HMIs. One system uses a Exter K20m, I connect to it using RS232C serial and I...
2,175
Hi. I need to get an upload from a Cimrex 30 HMI. According to a label on the back, it's made by Beijer. See attached photos. It's successfully...
2,606
Hi all, We need to change the IP address on an old Beijer Cimrex 91 we have in the field. I know there's a switch that you can change the position...
1,762
i m facing problem in establishing communication b/w Cimrex 20 and **** **** is modbus master on RS 485 as per **** it will take updates from...
12,285
169
