circuit board identification
goxx
Jan 2005
84
on my curcuit board, i have a component with 5 legs, it is labeled with a U. what is this? thanks in advance, and happy new year.
Did it originally have 5 legs? or did some drop off ? you could give a bit more of a clue as to the use of this board , maybe someone could tell you what you device is .
A number of manufacturers used U instead of L for identifying chips. They were not really considered Integrated circuits but were not transistors. Usually they contained a pair of transistors with common collector or emitter and were commonly used as a differential amplifier. They were a predessor to the OP-AMP in some cases.
appreciate the help. can't provide photo or give more information, this was the information and question asked of me from a fella on another shift. i will pass along the info yall have given. thanks!
Good Evening , Just wondering . We have a circuit board on a laser , that we are having low voltage issues with . I took notice that the...
2,527
HI ALL Can any one help me to implement a modbus slave board any one have a complete circuit board for a mod bus server ?
2,924
We are building a control panel where I work and have to incorporate 3 printed circuit boards that are about 4 1/2" x 5". We want to put them in...
1,761
Hi, this is not necessarily related to automation, but it is related to electronics and I like to mess around with my electronics when they go...
40
12,749
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
236
