Does anyone know what this component is in a circuit board?
Open circuit, blown fuse or overload device. Replace with nearest similar available equivalent.
If you have a can of "Freeze It", just for giggles you could cool it down to see if it starts conducting again.
Your power supply circuit appears to be low power. Can you determine the rating of the F701 fuse? The bad one would be smaller than F701, most likely.
That's what I thought. Why did I narrow into this component? well, all caps also looked pristine and the rest of the diodes seemed to work ok while tested soldered to board. This is the only one that would not conduct.
Anyway, that's the idea, to replace it, but I have not been able to identify what the component is...
I'm on my way out right now, but will test freezing it tomorrow.
Thanks!
I would replace it with a Bussman or similar Slow Blow ceramic fuse, sized lower in amps below the main fuse F701.
Or if I couldn't find a spare fuse, a piece of very small wire to see where the smoke comes out! You were going to replace the LCD screen anyway, right?
Using a Fluke? If so, OL means OverLoad or unmeasurable infinite resistance, same as an open circuit.
If it's a varistor, then it should have a nearly infinite resistance until it reaches it's clamping voltage.
http://en.wikipedia.org/wiki/Varistor
I've never stuck an ohmmeter across one, so I don't know if it would read infinite or not... :unsure:
-Eric
The picture in post #9 looks like a silicon glass diode. Do you suppose the part number SG702 prefix "SG" (as in silicon glass) on the circuit would be a clue? Just looking at where the component is located seems like where an ordinary diode would be. I think that the fuse at F701 would be all that is necessary instead of having 2 fuses that close together on the board. It would be nice to have a picture of the reverse side of the circuit board to see how the foil strips interconnect the components.
Eric, I believe that you nailed it down. It all makes sense now. I see 3 of those SG's in that CRT monitor Schematic #9. I imagine that surge currents and lightning are big problems for monitors.
If that SG701 in Sergio's circuit appeared to be melted, then probably it shunted a large spike to ground, and other parts may have been damaged at the same time.
Just to add to the confusion...
Perhaps the 'SG' prefix stands for 'spark gap'?... :confused:
I think that you are correct, especially since it's right next to a MOV.
@OP, Context would be nice. Flip the board over and take a shot of that please.
Nobody can answer with certainty if the circuit is not also provided. PC traces (the circuit) must be defined to know what connects to what. The part could be damaged meaning its function cannot be measured. It could be a diode, a thermal fuse, a bidirectional avalanche diode, or many other possible device. Defining a schematic (interconnections) is necessary.
BTW, there is no such thing as a surge absorber.
It may be misnamed, but that is what the Chinese are calling a spark-gap device that shunts excess current to a ground point.
It's no wonder people read these forums and become more confused than before they came.
I read the topic with interest. I didn't know for sure what it was.
Then surge absorber was mentioned with pictures to back it up and I thought excellent work boys in identifying it.
Then after that we still get clever dickies guessing but stating it as 'fact'
New readers don't know who to trust and who not. (sigh)
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
421
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
820
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,056
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,263
