Does anyone know what this component is in a circuit board?
It may be misnamed, but that is what the Chinese are calling a spark-gap device that shunts excess current to a ground point.
Shunting means it acts like a wire. Does not absorb energy. A surge absorber does not exist even if a Chinese to English translator gets it wrong.
It may be a spark gap. Or may be any of other above suggestions. No conclusions exist - only speculation.
A definitive answer exists when interconnections are defined. That device even looks similar to a 1N4148 diode - among the many possiblities. If to be replaced, then spec numbers for a replacement part also must be defined. Just another reason why interconnections need be defined.
Dont you have anything more important to waste your time with ?
edit: I want to be anal retentive too. Here is a link that explains that a "shunt" can be a "ligthning arrestor": http://en.wikipedia.org/wiki/Shunt_(electrical)#Lightning_arrestor
Thats what I thought at first, but looking closer, no it cant be an 1N4148 diode.
And it is probably not a diode at all.
Think about the -(Z)- symbol underneath. It has no polarity. How would you know which way to install the diode ?
Look at the components. It's a power supply. MOV's, caps, chokes.
It's a spark gap. See posts 22-25. They are accurate.
I agree with post 30.
If we had tried, by now we could together have designed a new circuit that did not use this Spark Gap.
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
424
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
823
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,056
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,263
