Citect 2015 - Multiple Monitors
Peter Laing
Oct 2005
BC
73
Greetings All,
I'm looking for some advice on using a two monitor setup in Citect 2015 (7.5). I've been working with Citect for many years but I've never had a need for multiple monitors until now. Here's what's happening:
I've set the MultiMonitors parameter section in Citect.ini as follows:
Monitors = 2
StartupPage1 = A_Main
StartupPage2 = B_Main
So far so good. The respective pages display on monitors 1 & 2. But when I try to raise a popup window from the page on monitor 2 the popup displays on page 1. This is the command to raise the window : WinNewAt("PopupFaultA1AlarmStatus", 0, 0,(2+8+64+128+256))
Seems like this should be trivial. Any ideas guys?
Thanks,
Pete
Thanks Gary,
I found a copy of the article you mention in the Citect KB - I'll start from there. I hadn't bothered to search the old documentation since I read somewhere that multi-monitors were 'fully' supported as of v7.2. Hopefully it's not too much of a DIY project lol.
Cheers,
Pete
Here are a pair of functions that solved my issue. Use WinOpenMPExt as a replacement for WinNewAt. GetMou provides the page X offset. In my case a page Y offset was unnecessary.
//FUNCTION WinOpenMPExt
// Opens specified window near absolute mouse position - useful when opening popup window on second monitor.
FUNCTION
WinOpenMPExt(STRING sWinName, INT iX, INT iY, INT iMode)
IF WndFind(sWinName) = 0 THEN
WinNewAt(sWinName, GetMousX( ) + iX, iY, iMode);
END
END
// FUNCTION Get Mou***
// Returns absolute mouse position (x)
INT
FUNCTION GetMousX()
INT iMousX, iMouseY, iX, iWinX;
DspGetMouse(iMousX, iMouseY); ! Get the mouse position relative to current window
iWinX = PageInfo(14); ! X Pos of current window
iX = iMousX + iWinX; ! Absolute value for X Position of Mouse
RETURN iX;
END
just wondering if anyone has worked previously on Citect SCADA 2015 (V7.5) before they upgraded Citect SCADA 2016 (V8.0). i have to upgrade my...
8,479
Hi I'm trying to talk to a SCADAPAck 334E via modnet (citect). The channel does show as online in the main kernel window but in the unit kernel...
2,504
59
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
85
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
73
