Vijeo Citect 2015 SCADAPack 334E Modnet
Pfisher92
Sep 2016
QLD
Hi
I'm trying to talk to a SCADAPAck 334E via modnet (citect). The channel does show as online in the main kernel window but in the unit kernel it's offline (starting every 30s).
As I wasn't able to talk to the Scadapack from my actual citect project, I've setup a test citect project with nothing but a single tag just to prove the comms. I still haven't actually been able to read this register yet. I've run through the various Modnet alterations (2,3,30 etc) with no success - I'm reasonably sure it should be straight Modnet?
-Modscan32 is able to read the registers i'm trying to read from citect (with the correct value). (Register 40013) - In citect I've tried reading registers 40014,13&12 with no success - the unit kernel always says offline.
Any help is appreciated.
Hi
Check out InitVar and InitVarType in the ini file, to start comms the Modnet driver uses a fixed address to check if the unit is active, if it doesn't exist it wont start.
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
483
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,674
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
893
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
734
I am trying to import a genie from an old project to new project, but I cannot do it and didnt find any answers yet on Google. Can anyone help me...
754
