Citect 2016 with S7-1200
LEGERVI
Jul 2017
Kingsbury
Hi, I need to make communication between Citect 2016 and S7-1200.
The S7-1200 model is (215-1AG40-0XB0).
I'm able to make that work with address acces from Citect to PLC with KepServer.
But I need to make that work with tag access. Not with address.
In Citect I found S7TCP driver but I'm not able to make it work.
In the manual driver manual they talk about S7-1500 but nothing about the driver with an S7-1200.
Does someone have ever done that?
Thank you for the Help.
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,181
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,975
just wondering if anyone has worked previously on Citect SCADA 2015 (V7.5) before they upgraded Citect SCADA 2016 (V8.0). i have to upgrade my...
8,480
Hi all, Does anybody know what the replacement for the DspAnMove command is? i could really do with being able to move an object referencing x y...
2,182
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver. Thanks
27
17,929
