Citect Alarms disapear.
kire
Apr 2014
UK
55
I have a SCADA (Citect 7.20 SP4) system who has runned for moths and alarm history have worked as it should, but know is has stopped working correct.
If I goes into Alarm history I only seen alarm who is newer then 60 minutes, and when i monitor the list I can see that alarms who are older then 60 minutes dispear....
I have tried to shutdown primary and secondary server (two computers) and delete all alarm log files I have found and then start up Citect again without any luck... Can it some files I should have delete, but not have found?
All files in, have been deleted:
C:\ProgramData\Citect\CitectSCADA 7.20\Data
Citect.ini:
[Alarm]
HwAlarmFmt = {Time,12}^t{Tag,25}^t{Name,25}^t{Desc,25}^t{ErrPage,25}^t{ErrDesc,25}
SavePeriod =600
SavePrimary =C:\ProgramData\Citect\CitectSCADA 7.20\Data\SavePrimary
SaveSecondary =W:
ScanTime =500
SummaryLength =1000
SummaryTimeout =60
I`m thankful for all feedback / inputs.
Thank you.
Hem... Can these be the reason?
31.01.20119:44:18 (plese see attached document for whole string).
Can these be the issue year format is wrong, so alarm page don`t are abel to read the log in the log files?
Where can these be fixed, havent found the place to update format...
Hi guys, its my first time progamming cicode and I need to do popups alarms, there are several digital alarms and in their rising edge transition...
519
Hi Everybody Im working in a project, the architecture is 1 server & 1 client. Everything works fine except the alarms sound in the client. When...
1,035
Hi All, I'm working on a site that's running Citect 7.5 and they've asked me to try show only certain alarms on specific machines. I was thinking...
2,086
Hi everybody, I'm working on a project where i am trying to use local variables to activate alarms but i cant get it to work, so any help would...
3,483
Hi All, The Scada system is not displaying the alarms but displaying / controlling all other signals. The basic alarm server configuration /...
3,619
