Citect Alarms
pdsdownunder
Dec 2011
Newcastle
20
Hi All,
I'm working on a site that's running Citect 7.5 and they've asked me to try show only certain alarms on specific machines.
I was thinking of using the INI file on each client to identify each machine and use that as a filtering process.
Is there an easier alternate method...I see they haven't set up an area tag?? could this help??
Thanks in advance.
I do have access to the Engineering workstation and servers...I've created new users which are just the clients machine names on the LAN. I've then added an area number to the area column in the digital alarms dbf file as a test. What I was hoping to do was when a client started up it would take its Machine name from the INI LAN parameter ( which is now a new user) and only have access to alarms assigned to that user...make sense.
I think I've assumed wrong in that in the "Roles" setup of Users the "View Area" has nothing to do with the Alarms Area in the digital alarm setup??
Hi guys, its my first time progamming cicode and I need to do popups alarms, there are several digital alarms and in their rising edge transition...
519
Hi Everybody Im working in a project, the architecture is 1 server & 1 client. Everything works fine except the alarms sound in the client. When...
1,035
Hi everybody, I'm working on a project where i am trying to use local variables to activate alarms but i cant get it to work, so any help would...
3,479
Hi All, The Scada system is not displaying the alarms but displaying / controlling all other signals. The basic alarm server configuration /...
3,617
Hi, I have a SCADA (Citect 7.20 SP4) system who has runned for moths and alarm history have worked as it should, but know is has stopped working...
2,948
