Citect comms with Siemens MP270
I Haven't seen a link like this but if you can connect it to softnet (you always have to go over softnet or an opc server if you want to communicate to siemens with citect) you should be able to connect it to citect.
greetz,
Marsupilami
I'm wondering if anyone has any insight into Siemens communications and may be able to help me with a communications problem I'm having? I have a...
4,197
I have been using S7-300 & 400 PLC's communicating with Citect SCADA via Profibus using Siemens CP5613 cards installed in each PC. For very small...
20
37,092
Hi, I'm a first time poster. I need to establish a connection between an FX5U PLC to a Citect PC. I will be using a MODBUS TCP - MODBUS SERIAL...
3,988
Hello All, I am running Citect SCADA 2018 R2 and trying to connect to a AB ControlLogix L81E. I have configured the board, port and IO device...
1,921
Hi guys, I have a client with a siemens S7200 PLC (1215C CPU),which has an on board ethernet port (marked "profinet" on the PLC) and I need to...
1,537
