Citect - Disable checking *[General]CheckAddressBoundary*
ongzy
Dec 2010
Selangor
100
The Vijeo Citect compiler displays the "Address on bad boundary" message if the address of a long or real variable is not aligned correctly.
Allowable Values:
  • 0 - (Disable checking)
  • 1 - (Enable checking)
Default Value: 1
Where to edit the .ini file?
I've just figured this out.
Citect Project Editor > Computer Setup Editor *Down right corner*
Section: General
Parameter: CheckAddressBoundary
Value: 0
-> Press Add, and then save.
*Make sure you save a backup copy of your citect.ini file first before attempting the above.
you can also do it in the ini file.
But be careful, I have found that on some PLC's (Ti series) that regardless of wether you disable the boundary checking or not Citect can have comms problems if all of your multiple word address's are not on the same boundary. INT's are OK but we have had problems with REAL's when some of them are addressed to the odd address (eg V123 the REAL value in the PLC is stored in address's V123 & V124)and others are on the even (eg V124 the REAL value in the PLC is stored in address's V124 & V125)
Be careful with changing this parameter. Some drivers can give unexpected results when integers and longs are not on even addresses.
Regards,
Marsi.
Section: General
Value: 0
Thanks a lot.
Regards,
Marsi.
That's not really a problem with the parameter as such, that's more a driver/device issue, address boundary parameter does what it says on the tin, just stops a check and subsequent compile failure if they are odd/even.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
66
74
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
112
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
79
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
85
