Citect disk variables location
downriver_bob
Nov 2017
Gundagai
17
Can anyone help me out with where the file for the citect disk variables is kept?
I have a variable tag "email_reception" on device"disk" at address "s200" and I don't know where I can find location "s200" and see the tags actual value.
The actual file is somewhere in the c:\ProgramData folder typically a few layers deep. Sometimes that folder is hidden so you might need to set hidden folders to visible.
However even if you find it I don't think you can easily read the file. Better to make a new page and have a field display the data you wish to see. Or to configure your Citect as an OPC server and then use an OPC client to view the current status if you do not want to add new pages.
Hi mp,
Thanks for your reply. I'm quite unfamiliar with citect, but have worked with Rockwell's FactoryTalk plenty so I'm finding the adjustment difficult with no training.
I think I've found the file, tried to read it, and as you suggest is pretty much worthless. Is it safe to say the only proper way to change the disk variables is to have an input field on the display somewhere? This project may have had an input field at some point and the data edited previously, but now that field has been removed?
do a search for the tag email_reception its probably in a cicode file somewhere in the project.
yes i would create a button on a page and use that to write to the variable.
Thanks for the replies.
EICS,
I have searched for the tag and s200 is the only reference I can find to a place where it might be substituted for an email address. It appears that instead of a "[email protected]" format it is using the outlook address book and referencing the alias instead somehow? Any ideas as to where this may be configured so I can confirm?
sigmadelta,
Thanks, I understand what it is, but am unfamiliar with how it is stored and accessed
interesting
do you have an "Included" project as part of the main project?
if so make sure your search criteria has this selected. have you searched for "S200" as well as the tag?
what version of citect are you running? search from the "project editor" if you have not done so already and check all the boxes for search criteria.
I don't believe there is an included project, but I have done the searches with that option and have the same results.
Searching "s200" only displays the result in the tag variables, searching"email_reception" displays the tag variable result as well as the locations in the cicode.
We are running version 7.2 and I have done all searches in project editor, where else could I search from?
As was said before - the only way that the internal variable tags are written to is via a page in the graphical interface, or some cicode. You won't see any reference to s200 outside of the tag configuration. Every other reference will be to email_reception.
Perhaps there was a reference to it previously and that isn't there anymore but most likely it's in the cicode somewhere. If it isn't, and you reset the IO server you might wipe that email out with no way to re-write it.
you might see a line saying 'email_reception = [email protected]l' or maybe a function call for TagWrite('email_reception', '[email protected]')
I don't think there's any other way to get data into that tag.
A good trick would be to write to it, and write a different value. Then wait and see if it changes back sometime. If it does, there's something in your project doing that
if you want to email your project to me i will have a look next week, off site at the moment but monday i will be back and have access to V7.5 which should restore it without issue
let me know.
Is there any way to access the disk I/O variables in citect V5.5, there is one tag available in the variables.dbf and it is defined as disk I/O...
1,771
Hello, Some variables in an old Citect program (V5.42) are hash comms. After some investigation, I have noticed that they are not looking at the...
4,549
So I have need to display volume and run times on my screens for some equpiment. I recently got some help from support but things are still not...
11,535
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
32
