Citect function debugging
atomtm
Jun 2014
Germany
130
Hello everyone ! Is there a way I can monitor what functions are used when a project starts ? For example could I print a message whenever a function is accessed ?
Thank you in advance!
Are you familiar with kernel debugging in Citect? You can enter the kernel of the Citect process and run a 'Page Table Cicode' command to see what Cicode threads are currently running. This will help you find any periodic functions such as events that are initiated on startup.
Also, the Cicode Editor has a built-in debugger you can enable. You can add breakpoints to whatever line of Cicode you want and enable Cicode Debugging in the top menu. You can use that to step through any code that triggers a breakpoint. Your messaging suggestion also works as well, as Cicode also has the DebugMsg function which prints messages to the kernel and the Message function which displays a message in the runtime.
Thank you very much for your response.so in the kernel should I input Page Table Cicode?This gives me only PageFg while project is running.Is there anything else I should enter?
That just means no cicode functions are currently running or waiting to run at the moment you entered that command.
Is there any particular reason why you need to know what Cicode functions are running on project startup? If you're just trying to debug a particular project, it'd probably be much easier to just analyze the project files to see what events or startup functions are configured. The Citect.ini file should have all that information.
Do you have the Citect project backup in a .ctz format? I'm not 100% certain, but I think .ctz backups also include the citect.ini file as well as the actual project files. If you rename the extension to .zip and manually unzip it, you might find the citect.ini file there.
Otherwise, you should consider getting a backup of it somehow. Citect.ini files contain a lot of useful configuration information that will probably answer most of your questions. If there are startup functions defined in the Citect.ini file, you probably won't find that out just from looking at the Citect project unless the Cicode is sufficiently commented.
The citect.ini was indeed in the ctz . That is nice ! However if I try to replace the file in C:\Windows and start the project I get an error indicating that I may have a corrupted .ini file . So I guess I just have to inspect the .ini file and find required information.
Any hints for finding what functions are running on startup ?
Thank you !
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
485
Hi guys . Im trying to monitor gas detection controller Vortex model from Crowcon /UK on Citect SCADA by modbus RTU RS485 . Reading analog value...
1,798
Hi everyone, I'm new to Vijeo Citect. I have to upgrade an existing project which i only have to add a few DPM in existing pages. I managed to...
3,106
Hi guys, I am doing upgrading job from v550 to v610, however during compilation i see error "Incorrect number of arguments for function", wat...
3,097
Hi If any Citect guru would see this, I'd be very :bow: and even more if answers... Using v7.10 and would like to get some .pdf or something, to...
3,566
