Citect Historian / Reports Deployment Manager
s176m144l
Apr 2016
Ankara
Hi Everyone,
I am using CitectHistorian 4.5 and ı have a problem with deploying the reports. When i click to the Deploy Report in the Historian Reports Deployment Manager, it's says "Unable to determine default SQL instance name" which ı hope someone can help me with this.
Thank you
Is that a new install or an existing one ? If its a new one have you followed the install guides EXACTLY, if you miss one step you will be in trouble.
In my experience Citect Historian/Reports are tricky and we always rely on Citect Support to resolve issues, i think that would be my first call with an issue like this.
Thank you for your help guys, but ı am quite sure that i installed the program as described in the installation guide. And ı uninstalled all of SQL setups and vijeohistorian setups and i installed again as in the installation guid, i still get the same error.
Did you create a new SQL instance of a different name ? Is SQL on the same box ? are your firewalls off ?
I really would suggest giving Citect a call they will probably do a remote session, there isn't really an easy way for anybody to sort this sort of issue without being in front of the server/PC.
Hi All, Just wondering if anyone has been able to setup a Directquery on Power BI to the historian SQL database. I have been able to setup a...
1,169
Hi All I've recently been tasked with the implementation and installation of a Historian system into a plant, and I’ve encountered a major issue...
2,620
46
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
70
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
72
