Citect MailSend() with attachment fails
IainH
Jul 2008
Sussex
44
I am trying to send emails from a Vijeo Citect V7.20 project using the MailSend() function. However, when I try to attach a file to the email, the MailSend() function always returns a General MAPI Error (MAPI_E_FAILURE).
I can use the contents of the file as the body of the message, but, as it can be quite large, I would prefer to send it as an attachment.
I am using Outlook Express as that is available with the OS.
Is there any known solution?
Iain
I was able to do this by using some VBA code. which didn't require a running email client. Found it on a MSACCESS (Utteraccess I think) forum. will see if i can dig it up.
Thanks, it's worth a try.
However, the email client is not running, the MailSend() function accesses it's functionality whe required to send an email.
I have read that it is a confirmed problem with Citect V7.0 and that there may even be a hotfix for V7.0r3?
Iain
Iain
We gave up in the end with the in built Citect Mail functions, they are pretty flaky using MAPI, as you are discovering. But is it actually finding the attachment file successfully ?
Can you not get authenticated SMTP access, its much easier than relying on Outlook express....
We sued a third party application in the end but I guess you are not looking for suggestions that way.
Ideally, I would like to use the built in Citect Mail functions - this is a simple add-on to an existing product that would give us regular updates of the machine status.
I'm reluctant to re-invent the wheel just to make it go round!
Iain
Create a VBA Code item in Citect.
Option Explicit
'Values 8, 9, 10, And 13 convert To
'backspace, tab, linefeed, And carriage return characters, respectively.
'* CDO.Messsage
'***********Send Email Without warnings***************************
'* Variables: sendTo - list of recipients
'* Body - text to display in email
'* Sender = "Your Sender"
'* smtpServer = "10.29.127.1"
'* smtpServer = 25
'* To add attachments use this line
'* .AddAttachment "c:\temp\readme.txt"
Public Sub sendCDOEmail(sendTo As string,Body As string, Attachment As string)
On Error Resume Next
Dim myMail As Object
'Create Object
Set myMail = CreateObject("CDO.Message")
'Create Email
myMail.Subject = "Your Subject"
myMail.From = "Your From"
myMail.To = sendTo
myMail.TextBody = body
myMail.AddAttachment Attachment
'** Configure Remote smtp server **
myMail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of remote SMTP server
myMail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "10.29.127.1"
'Server port
myMail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport")= 25
myMail.Configuration.Fields.Update
'**End Configure Remote smtp server**
'Send it
myMail.Send
Set myMail = Nothing
End Sub
Call this code from cicode using the VBA call cicode functions eg
VbCallRun(VbCallOpen("sendCDOEmail", sMobile,smessage))
I was sending the email to a email to SMS server sMobile would be the emaill address
Iain
Are these message going outside of the building or just internal, if external SMTP is the much better way to go.
Is this an existing bit of code or are you modifying to add the attachment ?
Have you run the code in debug to check its getting the attachment file names etc. correctly ?
Is the mail even getting to Outlook express ? I remember when we used it i had to run some weird script outside of Citect to make sure Outlook was sending the message.
Just a few thoughts......
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
70
79
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
114
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
79
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
85
