Citect - Passing tags between Functions ?
EICS
Dec 2008
Melbourne, Australia
323
Another Cicode question if i may.
i have 2 Functions in cicode one function calls the other and i need to pass 2 Variables from one to the other and possibly a return value.
Would like to keep the 2 different functions rather than roll into one.
FUNCTION
Test_A()
String sTagD;
Int iTagF;
code;
code;
IF Code THEN
sTagD = "something";
iTagF = 5;
Test_B();
ELSE
Code;
END
RETURNED ! Returned Value from Test_B
code;
code;
END
FUNCTION
Test_B(sTagD, iTagF)
String sTagH;
INT iTagK;
code;
code;
IF Code THEN
sTagH = "Something Else";
ELSE
Code;
END
RETURN to Test A???? ! Return INT iTagK value Back to FUNCTION Test_A
END
Try This.
Code:
[B]FUNCTION[/B]
Test_A()
INT a,b
STRING sResult = ""
      a=16;
      b=8;
      sResult = Test_B(a,b);//TEST_B() function returns a STRING.
                            //INT a & b are passed to Test_B()
END//
STRING//<<Data type of return data (the default datatype is INT)
[B]FUNCTION[/B]
Test_B(INT x, INT y)//<<int x & y passed from Test_A()
STRING sSum
       sSum = InttoStr(x + y);
RETURN sSum;//<<sSum is the value Returned
END//
your code works a treat, many thanks.
i now just have to modify it for what i need in my functions.
Thanks chelton.
Try This.
Code:
[B]FUNCTION[/B]
Test_A()
INT a,b
STRING sResult = ""
      a=16;
      b=8;
END//
[B]FUNCTION[/B]
STRING sSum
 END//
can this be modified to Pass 3 Variables as per Below? can the section in RED be changed for say iTag_A, iTag_B, iTag_C or is the x,y,z convention need to be used?
Code:
[B]FUNCTION[/B]
Test_A()
INT a,b,c
STRING sResult = ""
      a=16;
      b=8;
      c=4;
       sResult = Test_B(a,b,c);//TEST_B() function returns a STRING.
                            //INT a, b & c are passed to Test_B()
END//
[B]FUNCTION[/B]
Test_B[COLOR=Red](INT x, INT y, INT z)[/COLOR]//<<int x, y & z passed from Test_A()
STRING sSum
       sSum = InttoStr(x + y + z);
 END//
[/quote]
Code:
[B]FUNCTION[/B]
Test_A()
INT a,b,c
STRING sResult = ""
      a=16;
      b=8;
      c=4;
END//
[B]FUNCTION[/B]
STRING sSum
 END//
[/QUOTE]
Absolutely. You can pass more arguments. Different Data types. Variable names dont have to be x,y,z it was just showing an example.
But you do have to pass the correct number of arguments and correct data type to the function being called.
Hi All, I am trying to pass a variable from Genie to Supergenie. I created a supergenie page with a whole lot of texts, custom genies and numeric...
2,857
Hi All, I'd like to know the best way to go about passing more than 8 variable to a super genie. I'd like to create a genie that will need to...
8,483
61
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
86
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
73
