CITECT 2016 Genie-Supergenie Passing Variable
akash11132
Jun 2017
Sydney
45
Hi All,
I am trying to pass a variable from Genie to Supergenie. I created a supergenie page with a whole lot of texts, custom genies and numeric entries with ?Placeholder? .
I have also created a genie button with %placeholder% text. The %placeholder% value is provided by the user.
Is there any way to pass the %placeholder% value from genie to the ?placeholder? value in the supergenie page?
I have tried the metadata associations. In the genie metadata properties, I provided the metadata name as 'Placeholder' and Value as %Placeholder%.
Similarly in the Supergenie page Association properties, I have set the association name as 'Placeholder'.
I am able to see the %placeholder% value provided by the user in the genie button. But , I am not able to see the ?Placeholder? value in any of the texts in the supergenie page.
Regards,
Akash
Thanks a lot Wasan. That is what I was exactly looking for.
I have followed every steps. While pasting the genie button in the graphics page,I have provided '1' in the placeholder during the prompt to pass 1 to ?placeholder? in the supergenie page.
But After compilation, I am seeing the ?placeholder? in supergenie as ?placeholder? only . The '1' is not getting passed to the ?placeholder? in supergenie page. Any solutions for this problem.
Regards,
Akash
Could you show us your setting of Super Genies, Genies, Genies parameter when you place it on graphic page and .ctz files of your project?
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,180
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,975
Hi, I need to make communication between Citect 2016 and S7-1200. The S7-1200 model is (215-1AG40-0XB0). I'm able to make that work with...
1,141
just wondering if anyone has worked previously on Citect SCADA 2015 (V7.5) before they upgraded Citect SCADA 2016 (V8.0). i have to upgrade my...
8,479
Hi all, Does anybody know what the replacement for the DspAnMove command is? i could really do with being able to move an object referencing x y...
2,181
