Citect SCADA have no suitable protocol for GE PLC CPE400 redundancy
hansenkhoo
Jan 2019
kl
Hi, I had a client upgraded their system to use a set of redundant PLC system with GE PLC CPE400, and a Citect 8.0 (2016) SCADA to get data with.
The problem is I cant find a suitable protocol for their communication, as I am using UDTs for most of my PLC tags, which is unable to assign memory address.
First we tried OPC UA, but redundant IP doesn't support OPC UA protocol, only hardware IP supports, which defeats the purpose of redundancy when I cant connect to both at once.
Then I tried SRTP, but too bad Citect driver doesn't support symbolic addressing.
SRTP, ModbusTCP, and other protocols needs memory address to be read, which my UDT tags cant be assigned one.
Anyone can help me? thanks
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
289
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
361
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
269
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
728
Hey, I'm trying to do the following, I have some experience with Citect but can't seem to figure this out. I/O Tag: BoxPos1_ProdNum (Data Type...
580
