Citect Scada problem
simpy1972
Dec 2012
Victoria
:mad:
Hi all,
I have made a cicode file to input lines of data into our system upon the press of a single button on the citect screen.
I now need to simulate this citect button with a PLC input and im either missing the obvious or its beyond me as to how i can do this.
Basically, is it possible to run a cicode function from a PLC input? or can it only be done from a citect button?
My line of code is as follows:-
FUNCTION AddDumpRemotely()
_EnterOrdNo = _ShwOrdNum + 1;
TForm = " XXX";
_TruckType = 0;
AddOrder();
RETURN
END
The lines of programming after the AddDumpRemotely() function are the cicodes i want to execute.
AddDumpRemotely function is selected by the operator pressing an on-screen button, i need to be able to do what the operator does but by a PLC Input instead.
Ive added a line of programming into the PLC to allow for a remote input to be high when pressed and also added a TAG into citect for the same input and this works ok but i dont know how to get this TAG to run the FUNCTION above.
I tried to add the following to the cicode but to no avail as it either errors on compiling if i dont use a FUNCTION command.....
IF dumpbyremote=1 (which is my TAG)
THEN _EnterOrdNo = _ShwOrdNum + 1;
TForm = " XXX";
_TruckType = 0;
AddOrder();
RETURN
END
or it compiles but doesnt do anything if i put it after the FUNCTION command as it still needs the operator to press the on screen button for the PLC input to run the cicode....
TForm = " XXX";
_TruckType = 0;
AddOrder();
RETURN
END
All i need is for the remote input to run the cicode without the intervention of the operator pressing the on screen button.
Please help as i feel this is just something im overlooking.
Im using an OLD Citect version 5.3 with an AB 5/05 PLC.
Thanks in advance.
You need to use an "Event" (Project Editor->system->Events)
Name = Global
Time = (Leave this blank)
Period = 00:00:10 (Checks every 10 seconds)
Trigger = DumpByRemote=1
Action = AddDumpRemotely()
Ensure that the events is "Checked on" during computer setup.
Name = Global
Thanks heaps for this Greg, works perfectly :)
Hi guys . Im trying to monitor gas detection controller Vortex model from Crowcon /UK on Citect SCADA by modbus RTU RS485 . Reading analog value...
1,798
Hi All, Please advice me the issued that following slove the problem. Thanks. Bryan Image Link is below...
2,095
I need help with the problem attachment. Sorry, my English is not good.
2,034
Hi Dears i want to fill gaps between Trend's Graph. i referd to Citect Help And I tried Some Trend Parameters such as...
2,323
Dear all, I am quiet new to the CITECT SCADA and require immediate help. Here at site, there are 2 existing workstations in which we had to do...
2,199
