Citect Timer ?????
jimtech67
Jun 2002
New Jersey
507
Is there a timer function in Citect or CiCode ?
I would like to do the following:
Press a button have a timer start. When the timer is done I would like to set memory tag This tag will cause another button to appear.
I am using a OPC server that is comminicating to our custom product. No PLC so there are no timers available that way. The OPC part is working
GO JETS
lots of solutions for this problem:
you could store the time when you press button 1, then if current time > (stored time + x) show button 2
you could use the sleep or sleepMs function
regards,
marsupilami
thanks Marsupilami
the sleep was what I was looking for, something clean and easy. I figured there was funtion I just could not find what I needed in the CiCode manual.
GO JETS
Be careful of sleep - it can adversely affect the performance of Citect if used often and for a longer time period. Even sleep for 2 seconds can slow things down.
Is there a way to created a countdown timer that would display when a trigger becomes true and go away when the timer reaches zero?
3,427
Can anyone help me with making a display timer such as a stop watch display that starts from a button (and counts up) perhaps using timer(). My...
1,386
Hello everyone! I would want to add a TIMER that it counts the time from the start to the end of a process. I don't know how to do it! Could...
3,254
Is it possible to automatic set a output high during a period of time. For example: When its 10pm i want to set a output high , and when its 2am...
2,638
When I try to use a Timer with a Mitsubishi Q series PLC and Citect SCADA it wont compile it gives Bad IO Device Variable Have used this to view...
2,160
