ALAN001 Member A Join Date Apr 2010 Location UK Posts 30 Jun 11, 2010 #1 When I try to use a Timer with a Mitsubishi Q series PLC and Citect SCADA it wont compile it gives Bad IO Device Variable Have used this to view running time before with FX PLCs and had no problems Address: T10 Device type: INT
parky Member P Join Date Oct 2004 Location Midlands Posts 5,761 Jun 11, 2010 #2 Try using TC 10 for the timer, TS10 for timer up bit, not sure but in GXIEC you use TC,TS,TN for timer functions within the plc
ALAN001 Member OP A Join Date Apr 2010 Location UK Posts 30 Jun 14, 2010 #3 Thanks for reply Parky found all the data types eventually for the Q series.
