help in communicating GX Developer(Fx series) with Citect scada--- serial comm
Vijeo Citect To FX PLC
GX DEv does not connect to Citect. For connecting FX PLC to Citect SCADA use FX PLC driver in SCADA. Remember FX PLC driver is not in the normal pack of Citect, you need full version license.
sir,
if some how i need to use normal version of citect scada then is it possible to connect Fx plc with it. i have Gx developer, Kepserver, citectSCADA 7.20, In Touch available with me.
or does any other plc of Mitsubishi support serial communication with normal citect scada?
Mitsu PLC to Citect
If you want to use normal (Lite ) Citect with Mitsu PLC , make Mitsu PLC as Modbus RTU slave & then Citect Modbus driver can be used.
You need to add Modbus serial port to your PLC. That comes for around 4000 Rs.
You are again confusing with GX dev.
FX is PLC .
Its programming software is GX developer.
KEP is middleware (OPC server software ) which you can use for connecting SCADA to PLC.
Citect is the SCADA / HMI software running on PC.
Clear ?
sir if i use kep then i should connect GX dev to kep... and further kep to citect via opc driver.... ok???
A few weeks ago while walking through the back part of our plant an coworker and I found an old GE Versamax Micro PLC (IC200UDR005-BB) on the...
2,488
Hi everybody, I'm new to Rockwell/Allen Bradley and need some help here. The client has 4 SLC5/04 CPUs in the plant, all in a DH+ bus and...
1,710
Please help me in configuring my PLC and Internet setting. I have uploaded system architecture, please check out. Thank guys.,.,:(
1,170
hi everyone, my problem is that whenever i try to view accessible nodes or try to download the object files into my plc, it generates differnt...
2,520
1,380
