Communicating with S7-300 thru my PC....plzzz help
minerva
Jul 2010
Rawalpindi
hi everyone, my problem is that whenever i try to view accessible nodes or try to download the object files into my plc, it generates differnt kind of errors every time. i m using CPU312C, and PC adapter 6ES7972-0Ca23-0XA0, both the power and active Leds are on,and adapter transmission rate is set to 19.2. PG/PC interface settings are PC Adapter(MPI)<address=0,tranmission rate=187.5,highest station address=31,connected to com1 and transmission rate=19200. The MPI address=2( thru cpu hardware configurations). Currently with this configuration it is generating error that the local MPI address for the programming device/PC is higher than the maximum node address or wrong transmission rate or wrong interrupt set.
PLZ PLZ PLZ help me, i m really freaked out now, doing all this. 🔨
hi everyone, my problem is that whenever i try to view accessible nodes or try to download the object files into my plc, it generates differnt...
2,526
I have two 315-2pn/dp's connected via Ethernet radio. I want to be able to see Input bits remotely from either PLC. I read that it is possible to...
1,006
I have RS232 9 pins (pin to pin connection) connecting my laptop to panel view 300 with serial number : 2711-K3A5L1. I am using panelbuilder 32...
8,364
I am trying to upload from pv300 model 2711-k3a5l1 b that's a dh-485 dos someone know what type of driver i have to use and wat cable i should use
12,349
I would like to communicate with Simens S7300, S7400 using Visual Basic. I want to know any other possiblity except OPC to communicate the same.
4,388
