communicating with panel view 300
mmgch
Feb 2007
new york
I am trying to upload from pv300 model 2711-k3a5l1 b that's a dh-485 dos someone know what type of driver i have to use and wat cable i should use
Driver is: 1747-PIC/AIC+ Driver ( You will need a real serial port to use this driver) or if you have the 1747-UIC ( USB to DH485 converter) use it.
Cable with the 1747-PIC/AIC+ driver is AB's 2711-NC13 ( this is a straight thru 9 pin to 9 pin cable)
Thanks for posting the part number; that helps a lot because it tells you what kind of communication protocol and port is on the PanelView.
2711- means Standard PanelView
K means Keypad version
3 3 inch display
5 DH485 protocol with RS232 serial port
A Amber/monochrome display
L1 24 VDC power
The simplest thing to do is connect a straight-through serial cable and use the "1747-PIC/AIC+" driver in RSLinx. You need a built-in serial port and a bit of luck to make this driver work on modern computers.
Another connection method is the 1747-UIC, which is a USB to DH485 converter with both RS232 and RS485 electrical interfaces.
Could you describe the error message please? It would help to know which program window it's in (RSLinx ? PanelBuilder ?) and some of the text associated with it.
You can also bypass this problem and use a CompactFlash card and PCMCIA Type II adapter to upload the file out of the PanelView.
error (2258) unable to communicate with operator terminal, did not receive a response. i am using windows xp professional. i am using PanelBuilder32 V3.80. and using rslinx version 2.43.00
Sorry not to hijack the thread but I have same problem with a 2711-K3A2L1 PV300. I can't figure out what cableing I need to connect to it. Do I need an AIC+ module?
This might help
Mickey said:
This might help
Thanks.
I now have a Win98 laptop so I can run the PIC driver. I have the laptop connected to the PIC, and from the PIC to the PV300 I am using the 1747-C10 cable. I feel I have all the correct connections now, and I can see the PIC in Linx
Now my problem is that when I try to download or upload from the panel I get an error "Error(1022)- Target is not an operator terminal."
AB Panel view plus 1000 (reffered old 27111P) communicating with GE Versamax on its RS232 port is installed on site. It was asked to make a backup...
1,176
I am using Panel view 600 to communicate with my PC its a complete VM system installed at NTPC. its in off state and its front panel doesn't glows...
1,935
I have RS232 9 pins (pin to pin connection) connecting my laptop to panel view 300 with serial number : 2711-K3A5L1. I am using panelbuilder 32...
8,352
I am having a problem with a compact logix L32E showing values on the display of a Panle View plus 1000. My graphics are all there on my touch...
9,378
Hello, this is my first time on this site. I washoping somebody could help with the PLC 5/03 not communicating with the Panelview 600. The error...
7,165
