rvankoppen
Hello,
I am using CITECT V7.2 with the ABCLX driver to communicate to a compactlogix L30ER.
I want to make a simple string tag that I can key into from a display in CITECT and have the value write to the PLC string tag.
So far from the ABCLX help manual they are looking for this kind of structure.
DINT LEN
SINT[ ] DATA
To me this looks like I should format my string tag address (in CITECT variable tags) as:
Mytag{ 10 SINT[ ] DATA }
OR maybe
Mytag{ 10 LEN SINT[0] DATA}
OR maybe
Mytag{ 10 SINT[0] DATA}
There are many different possibilities.
All of what I've tried so far return a BAD value in citect. I am using 10 for length as a general number for now as the strings are intended to have a max of 10 characters.
If I use Mytag without any other extra fluff on the tag then I can read from the plc without issue, but I would like to write to the tag.
What they don't do is show a good example of a string tag after showing the structure like they do with all the other tags with array and UDT types in the help manual.
Has any ever successfully written to a logix type PLC string tag from CITECT before?
DINT LEN
SINT[ ] DATA
OR maybe
OR maybe
