Clarinet OPC to FTView SE Issue
Jan 2018
Seattle, WA
I've set up a Clarinet OPC server on a remote computer and am now trying to view these OPC tags in FTView SE. I have added the OPC dA server to it's own area in the FT Directory and am able to point it to the CLARiNET OPC server on the remote computer. However I am not able to browse any of the tags in FT View SE. However I can view the tags on a test OPC client on the same computer FTView SE is running. Any advice would be greatly appreciated.
Hello [email protected]
I am on a train writing from my mobile so I only read your email and glanced your screenshots very briefly. In general if on the local OPC client you can see the required OPC items but not from a remote client, you likely are having DCOM security settings issues. Are both workstations on the same Windows domain? If not DCOM security settings become a bit difficult. If the workstations are in the same domain, on the OPC server side you need to grant credentials to the user of the remote OPC client. There is a utility which lets you do this. It is call from the RUN menu or a prompt console with the command dcomcnfg.
Blake: My Clarinet OPC server is located in a different machine but same network, I work on windows Workgroup.
From inside your FTView SE server you add your new OPC server, in this case Clarinet.
Once your Clarinet OPC server is configured as part of FTview se you can procede to do what ever you want, in My case I used derived tags to pass info from clarinet opc server to rslink enterprise server.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
133
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
184
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
225
