Click PLC to Studio 5000 via Ethernet
forqnc
Jul 2009
Elizabeth City
149
I just successfully set up a Click PLC as remote I/O to a CompactLogic PLC. Everything is working but when monitoring an Analogue value it is split into 4 - 8 bit registers. Just getting my feet wet in Studio 5000, I have tried COP, FLL and even ADD instructions to combine the data in Studio, but I do no get accurate results. This same question was posted on the YouTube site by someone else with no response.
Any assistance is appreciated.
Thank you Ken, I'd used 4 previously thinking I needed 4 bytes, changed to 1 as you suggested and works great.
Thanks again.
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,153
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
259
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,134
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
689
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
529
