Closed Loop System Logic
Dera bsee
Sep 2012
Los Angeles
36
Hello all,
I have a question. I am familiar with PID control loops. I have a project I'm working on which is steam control for a batch. I have a heat exchanger and on it I have a control valve and a temp transmitter, but I also have a temp transmitter on the tank. My goal is to have the tank's temp at 180 degrees. Which reading do I use? The Steam_Temp or the Tank1_Temp to use on the PID loop or how would I come up with the logic in order to be successful on this system? :confused:
Hi Guys, During PID Tuning by Ziegler Nichols Closed-loop method, In TIA Portal there is a Trend Tool used to determine Ultimate Period; marking...
1,907
So it looks like i am stuck with an old reliance DC drive on this project instead of the powerflex dc w/ 22-COMM-E. That being said i am trying to...
1,193
Hello, I am trying to make an Automatic Coolant Dispensing station for my client. This unit will be stationed next to a CNC Machine to monitor...
56
14,611
We're implementing a second pump in a piece of equipment that pumps primarily water, or fluids similar to water. This pump is located in a stand...
23
13,275
I have a project where I need to use a proportional valve to control hydraulic system. Before, I used open loop and now I try closed loop PID with...
3,403
