I have a program that set the speed for a VFD via an 0-10v analog signal signal .
I am trying to read the analog signal from the VFD to the HMI, I have the DF channel set on the system configure and I have the HMI looking at the DF202.
I have no code in the click that is actually reading the channel but the channel is configured. I get no readings, can i just assign the DF202 in the address picker or do I need the DF202 to be active in the code.
Thank you
Thank you
