Codemeter Notification Annoyance
Mispeld
Feb 2017
VA
644
Every now and then, typically after switching the active network adapter, Codemeter will display a blank Windows 10 notification window and will also appear in the task bar.
This blank notification window stays on top of every other window, blocking a not-insignificant amount of screen space. If I open the Codemeter app from the task bar, it is also an empty window with no application or context menus -- the only options are minimize (to the task bar) or maximize. Clicking close does nothing.
System restart is the only way I have found to get rid of these annoyances. I hesitate to mess with the service or registry, as I don't want to create more grief. Using Task Manager to end the Codemeter application gets it off the task bar, but the dead notification remains.
Anyone know a a better work-around than restart?
[Control panel reports Codemeter version 7.51.5429.500]
Have you tried disabling its notification permissions? If you haven't, the below steps is how to normally stop notifications for a specific program in Windows 10
1. Click on the "Action Center" (Far right of the task bar just past the clock)
2. Right click on the notification.
3. Select "Turn off all notifications for xxx program"
4. Profit!
Thanks for the idea, Lem. Unfortunately it appears that the Codemeter desktop object is not really a Win 10 notification, it just looks like one. I forced the issue, and then found that Codemeter is not one of the applications listed as generating a notification. Thus no way to turn off notifications by that route. The always-on-top thing that it leaves on the desktop seems to be an application window, but with no borders, window controls, or context menu.
I have found that killing CodeMeter with the Window Task Manager will get rid of the desktop artifact as well as the Taskbar zombie, and with no known issues. A bit more convenient than restarting the PC.
If you're killing it from the task manager anyways you can always set the "CodeMeter Runtime Server" service to Manual startup type instead of Automatic.
Also check that its not being started from the startup folder, it can act weird if its running as a service and also being started by the startup folder.
I activated the Studio 5000 license with the CodeMeter on a virtual machine. Unfortunately with the subscription license I was unable to create...
1,267
Hello All This error popped up today out of the blue. I'm not quite sure the best way to proceed? I'd appreciate any help or direction anyone...
859
The way our rockwell licensing is set up (as far as I can tell) is that it is all hosted through CodeMeter. I have a VM with Licensing hosted...
1,257
I run a FactoryTalk activation server for our technicians. We have multiple licences for RS5000 and the Function block and GuardLogix addons. I've...
1,113
Hi all hoping someone here may have ran into what im having, tech support is not being particularly useful, had someone teamviewer in then go...
2,008
