Codesys multiple Ethercat masters on one IPC
aand74
Dec 2005
Deinze
131
If an IPC with Codesys runtime on it has two separate ethernet ports, is it possible to have an Ethercat master on each of them?
I do not find documentation or forum threads on this item.
CODESYS Control Standard L lists two instances capability for the following 3 field bus protocols...
Metric
EtherCAT/Profinet/EthernetIP
Standard L
2 Instance
see here... [ Link ]
but doesn't state if that is any two different protocols out of the three listed, or if you can create two EtherCAT or two EthernetIP or two Profinet.
You could simply download the Standard L package, and test it on a PC, they state that the unlicensed system runs for 2 hours at a time before shutting down. Then test if you can create two EtherCAT masters on two different NICs. See the note at the bottom of that page "Note: In demo mode, the software runs for two hours without a license. After that, a manual restart is required."
The first of their case studies on that page shows "2 CANopen master instances: at least license Basic M"
Sure CANopen isnt EtherCAT, but if they do one protocol with two masters, perhaps they do EtherCAT as well.
Could also contact their support.
Patrick
I was also going to say that it should be possible so long as you have multiple adapters to establish individual networks out of.
Is there any way to bind more than one variable to a Text field? I want to be able to doing something like this <Value> <Unit> 104.6 F or...
4,023
Hi! I know you can have multiple applications in one PLC but can I do the other way around with the same application in multiple PLCs some easy...
2,234
I want to change the setpoint of PID block in Codesys for every 1 hour. like that i have to give 48 setpoints for 48 hours. So how can I give 48...
1,526
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
296
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
