Codesys network variables = ni pxi network variables??
MrQ
Feb 2005
236
Does anyone have an idea on whether
CODESYS NETWORK VARIABLES are the same as NI PXI NETWORK VARIABLES
I will program a Codesys based Schneider system and will exchange data with a National Instruments PXI system. It seems as the NI has some form of network variables.
Anyoune have any experience with this?
I took a little look at the LabView documentation on their shared variables and while the concept looks similar to CoDeSys, I don't think they are compatible. The LabView shared variables look like a much more complex and capable system than the CoDeSys one.
CoDeSys relies on Symbol files which I don't see mentioned anywhere in the NI descriptions (although they may hide them under the scenes).
In the past when we've shared data between LabView and CoDeSys we used Modbus/TCP. With CoDeSys 3, it might be easier to use OPC but I have no experience with this.
It is possible to use a structure in codesys and have this send to labview (or other way around, however it has some problems with byte count.
simpler is to use OPC.
Hello, One question regarding Network Variables in Codesys. I am using an IFM system with CAN communication. I have a controller and a display...
4,842
Hi, Greetings, In one of my applications I need to create a network variable connection using UDP between a codesys target and Twincat controller...
4,778
Hello, i am kinda new at codesys and i want to make a comunication between one ifm cr0403 plc and a cr0451 hmi i have read a lot on the forums and...
1,914
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
296
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
