Codesys OPC server
phuz
Jun 2008
Mohnton, PA
1,044
Has anyone used this piece of software? I am trying to troubleshoot some issues surrounding this OPC server on a customer machine.
Recently, the entire computer will need to be rebooted because two of the data channels lose communication. I don't know if it is related to the PLCs being powered off at certain times, but it is always the same two PLC channels.
I checked with my son and he said that the OPC server will disconnect when the project is downloaded after an address change. The reason for this is that the server has to check the SYM file for these changes. I asked him to join the forum so that he can answer you directly.
Good luck,
Yosi
Yes, I am familiar with downloads breaking the OPC link, but there are no downloads occurring to cause these failures.
put this question in codesys.com forum and tell what version and what type of PLC is used all with version numbers etc.
in most cases it is because updating will be needed on the PLC side.
Need expert advice, Which OS support/compatible to install codesys OPC V3 Please assist. :utoh:
1,444
Hi all, I'm currently quoting a SCADA upgrade, and there's a CoDeSys OPC server involved. I'm upgrading the OS from Windows XP to Windows 7, can...
2,861
hi, I am currently working on a project that requires access to the data inside plc using Codesys OPC server v2.3 and I want the data to be...
3,026
hi.... i have an urgent problem, the case is am trying to connect FactoryTalk View 5.10 hmi with codesys v2.3, but i cant import tags from codesys...
10,092
I am trying to access the value of a pointer via OPC UA in Codesys. I can share it directly and in a struct but I cant access the value of it when...
1,621
