Codesys - SysSaveRetains??
electro89
Mar 2012
Canada
106
Can someone explain how the SysSaveRetains block works? What type of file needs to be called at stFileName? Can't seem to find anything useful online or in the manual about this. Whatever filename I put, it gives me a -1 reading, which if I understand means that it could not locate the file
I'm using Codesys v2.3 with the wago 750-841
Thanks,
Martino
you have to open a file and the filename is retain.txt for example.
ask this on the 3s-software forum and you will get answer from rolf.
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
295
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
160
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
509
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
174
