Codesys v3.5 SP12 - EtherCat interface
markopo
Aug 2009
Wrzesnia
Hi.
I'm dealing with configuration communication by EtherCat in Codesys.
As written in docs I've installed WinPCap, had changed CODESYSControl.cfg, loaded project with EtherCat Master and imported XML for EtherCat device plugged into RJ45 plugin. I writed MAC address for NIC for EtherCat. Nothing.
All the time I get info about "Gateway not configured properly" when I try go into the "Online config Mode...".
Please for Your help.
Mark
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
146
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
314
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
98
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
167
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
521
