COM Module has Rejected Reload HIMAX
msohaibbutt
Apr 2015
PK
I want to make some changes in Modbus configuration of communication module X COM 010 11 for HIMAX in SILWORX V11 but its asking me to cold reload. So i generated code, then stopped module from Hardware. When i reloaded from resource, the error came up "COM Module has rejected Reload. It will automatically be stopped and restarted. The connection may be interrupted or the module may remain in the STOP/INAVLID CONFIGURATION state." Also i tried download the resource. In download, i do not see this error but card does not go to Run state & stays in STOP/INAVLID CONFIGURATION state. Please help me resolve this issue. I checked when i tried to stopped this card for the first time from Hardware, it went to "SyncLock" instead of stop mode. Is that correct?
Hi, I used to use my Lenze EMF2102IBCV001 LECOM a/B module to connect to many Lenze 9300 series servo drives. Now I would like to connect to Lenze...
512
Hi, I have a Schneider M580 station equipped with a BMENOC0301 Ethernet COM module. The module is physically altered and we have decided to...
449
Hello All, I wonder if some of you can give me some insight in this problem that I have. Here are the symptoms 1. 1756-DNB/A DeviceNet Comm...
3,593
How can one determine the fastest RPI rate for a given module and not worry about future update issues if code and I/O rack configuration is not...
1,862
Dear All, I have a question about the modbus communication with CM PtP. I'm using a power meter to measure current/ voltage/ power, and the...
2,236
