comm link prob with dl105
prudent98
Feb 2011
secunderabad
Hi i have a problem with koyo DL105 is not communicating with the PC.
error: No response from PLC. How could i communicate with the plc.
While i'm estalblishing a new link : protocol: ksequence
port: com2
address:1
error: NO response from PLC
while i'm connecting the PLC from DS programing
error: error unlocking PLC
When establishing a new link I use the Link Wizard it should detect your plc.
Check and verify the correct comport is being used (serial port or usb). And the cable is connected, check pins for damage.
Which cable D2-DSCBL?
Have A Nice day
Hi i have a problem with koyo DL105 is not communicating with the PC. error: No response from PLC. How could i communicate with the plc...
1,396
Anyone program this doohickey using controllogix. If so, how and maybe an example. My brain hurts figuring it out
1,395
A dial in ethernet switch modem (SLX-5MS-MDM-1) connects PLC DL260, HMI EA7, and a computer through ethernet. ip address would be 192.168.0.10...
2,229
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
514
