Commissioning Standards
sparky64
May 2003
Newcastle upon Tyne
127
I've been given the task of commissioning a new machine, but i don't have any formal written procedures to follow, basically i will commission the machine using my experience.
I would like to know does anyone have any standard commissioning procedures that they would be prepared to give me a copy of, so all the techs on site will commission machines following the same written procedures, and tick off the relevant checks....such as Safety circuit, I/O etc etc.
Thanks for any replies
Sparky :)
If you send me your e-mail address i will forward you a PLC start-up and maintenance pdf document which looks quite good.
Hi garyt1. How about posting it as there are many of us that would be interested.
beerchug
i'm interest
hi...culdd you put this information in a mirror to download this i'm intersted in this information..thank you
excuse me...i'm sorry ..mi english in very bad
if anybody con help me ...post please
Hi Bob,
The problem is the size,its in pdf format and over 1meg in size.If you send me your e-mail address i will send it on to you.
Hey Sparky64,
I know what I am about to say is probably pretty obvious, but I think it warrents being said anyway.
Get ahold of all the written specs that were given by your company to the supplier. Make sure you have read them and understand exactly what was agreed upon.
Then get ahold of the proposal and any/all approval drawings and documentation. Check them against the specs. Obviously any discrepancies between the two will need to be investigated and ironed out in your organization first (and should have been prior to the order being placed, but may not have been).
Now that you know what you are SUPPOSE to be getting, check it out thoroughly. Make your supplier prove it to you. Measure foot prints, check wire numbers, clock cycle times, verify wire sizes, observe that each and every button does exactly what they say it does, disable sensors and observe the response, verify that every component is precisely the ones that were specified. In short, try to look at everything. One good way is have all your maintenance guys go over it with a fine tooth comb. You will get a lot of opinions you might rather not hear, but on the other hand, you might spot a bad weld or poor wiring practices, too.
And if you are allowed (by your organization especially) make the supplier run the machine for a specified period without ANY hiccups. To do this you will need to supply constant observation. If provisions for this were not in the original agreement, you may be out of luck, but I would try it anyway.
The more you can do like this the better. Not only will you uncover a lot of little problems, you will create a bargaining chip your company might be able to use to reduce some up-front costs or to get some additional features thrown in for nothing.
I have been on both sides of this this particular coin and this type of commissionings is very valuable.
My .02 worth.
Steve
I have to commission about 150 drives next week. The last couple times, I just used the BootP/DHCP tool. For anyone coming across this and...
2,649
Hello, After commissioning the V90 starterpakket follow siemens commissioning file...
1,139
These were here when I showed up in 1991 ... 31 years ago Allen Bradley SLC 100. .. Programmed with a hand loader Allen Bradley PLC 5/20 ... I...
19
4,725
Hello everyone, Currently I am performing preparations for a huge project. And there is a need to establish communication between plc and VFD by...
1,283
Hi, I am commissioning a Mitsubishi FR-V500 (3.7Kw) drive. I am able to get the drive to tune and spin up if I set parameter (Pr) 800 = 20 (V/F...
1,348
