comms problem between rslogix5000 and intouch
jamie90
Nov 2014
new york
Hi im having some trouble when comunicating between intouch and the plc. I have around 4000 tags . Some times it works fine but other it doesnt communicate at all , all the tags go red in the diagnostic tab under the SMC console . What could be the problem ?
Im using the SMC console and FSggateway together with RSlinx classic..
thanks!
Hi ! thanks for answering.. I get the message : "Initial update from OPC server after activation/creation of item '[My_project]N100.13' in topic 'MyPLC' never ocurred, injecting bad quality 18h... when comms goes wrong i get lots of these msg
Also I get :
-Failed to add Item N80:89/0 to OPC group 'MyPlc', HRESULT= c0040007
-Item N80:89/0 <02000318> poke failed [hr=c0040001]
-Write operation failed , all items are invalid. Calling remoretransaction and resposecomplete for message <037831f0>
Finally i get this one : ASBSecurity proxy: Connect null findresponse finding IManageASBSecutiry On the SR node MyNode
Have you checked your comm switch, is IGMP snooping active ??, what about ethernet comms, are they forced to 10 or 100 mbps (full duplex) ? The same for your plcs comms.
Hello, I am trying to get comms up between my PC and a Panelview 600. I have an Acer Aspire 5741 which I have loaded Windows XP Pro on and am...
1,876
Hi I am having trouble setting up the comms for the pv600 plus. I have ML1100 connected to a switch. The pv is also connected to the switch. I...
2,845
Good day; I'm having an issue with the FTView ME 11.0, because I have created and application for a PanelView Plus 7 andd all works correctly, I...
1,611
hi all, i am trying to connect a keypad display OP320-A to a fx48mr plc. The manual for the OP320-A gives a diagram for the cable which uses the...
2,597
I have a problem communicating between a 1400 and a L23E. I got a call that one of our systems had gone down and needed the program reloaded. I...
1,723
