Communicate to PLC 5 using 1756-DHRIO.
alhasas96
Nov 2012
manama
I have communicated to a PLC 5 via Ethernet network by using 1756-DHRIO from peer communication port DH+. But is it possible to communicate to a PLC5 by terminating Remote I/O Cable to 1756-DHRIO from 1771-ASB.
What is the procedure in details please? Your help will be appreciated.
That is a very good question, but the answer is no.
The Allen-Bradley Universal Remote I/O protocol (RIO) uses the same physical wiring structure as Data Highway Plus (DH+), but the protocol is only for I/O scanning, not for command and control of the PLC-5 processor.
You cannot connect a 1756-DHRIO to a RIO network as an 'Adapter', and you cannot communicate with the PLC-5 using a 1756-DHRIO connected to a RIO channel on the PLC-5.
If you require passing small amounts of I/O information between the ControlLogix and the PLC-5, you can use the 1756-RIO module, which can act as an Adapter (similar to a 1771-ASB). But you will not be able to 'go online' or have random data table access to the PLC-5.
hello, illustration on the file jointer. I connected with a PLC modem gprs remote that sends data to the GPRS modem connected on a local PC, I...
2,641
57
Hello i have a PV+1000 firmware ver 5.10 and a compact logix L18ERM VER 24. I googled and read many posts but still can not make simple button on...
561
Have matched communication parameters of both, DOPSOFT HMI and PLC Fatek. Yet an error keeps appearing "Failed to open port COM1". I believe...
688
Dear Members, Currently, I'm working with Hitect HMI spec PWS6600S-S and PLC FATEK PLC FBS-32MAR2-AC. We plan to do a replacement unit...
754
