communicate with s7-300 with usb-rs232 adapter
bara_hence
Aug 2007
Ockelbo
225
I have the original cable for the plc but I need to connect it to a usb port is it possible to buy a adapter (rs232-usb) and communicate with this?? I met an old engineer today that said that was impossible..
So far I have had no luck in using an USB/RS232 converter in combination with RS232/MPI and I have tried out a couple already. I'm very satisfied with my newer USB/MPI converters I (my firm, that is) bought from Siemens. I got rid of the communications bottleneck overnight. Now I'm able to program over 187.5kBaud all the way and even analyse DP connections on the full 12Mbit/s. Program status is also a lot faster. I think it's the best investment we have done in the past years.
Kind regards,
Ok thats to bad it´s a little expensive for me as a student to buy these things.. The reason I ask is that I was offered to work extra doing service on the plcs in a small factory and there i must communicate with s7-300. They have the cable and hardware but i must use my own computer.. And i dont have a rs232 port on it...
Do your laptop have a docking station ?
Some docking stations have a connector that connects directly to the laptops motherboard, not via USB, and in this way provide a "real" serial port.
nope no docking station.. I read on another site that someone had sucessfully used a rs232-usb adapter with s7-300.. So maybe it will work..
I use a USB/Serial adaptor with my PC adaptor, I never had any problems. I think the maximum baud rate is 1.5MBPS, but I usually use the MPI port so this is fine.
The PC adaptor is RS232 to MPI/DP 6ES7 972-0CA23-0XA0 V5.1
The converter has a FTDI chipset like this one; http://www.usbnow.co.uk/p48/USB_to_RS232_with_FTDI_Chipset_(1.8M_Cable)/product_info.html
My laptop is a HP Compaq Presario, my collegue used the same leads on his Dell, I think it will work with any PC.
Jason,
thanks for the info. Whenever I need a new converter, I'll look out for that chipset.
The converters I have are based on other chips and work fine with Allen-Bradley and Omron PLCs, but I didn't have any luck with Siemens. My PIC programmer also didn't work with these.
Kind regards,
I never heard of a 1747-PIC working with anything other than real serial. I have a brainboxes PCMCIA/serial card and it will not run the PIC.
Hi All I want communicate PLC S7 300 by VB.net and use Libnodave pass usb mpi 6ES7972-0CB20-0XA0. Can do it? If can please guide me. Thank you.
3,298
Hello there folks! I need to access certain DB data from slaves (IM 151, CP342-5) connected to master (CPU 315-2 PN/DP) via Profibus-DP. They're...
1,894
Hi Everyone, I want to know how we write the data to s7 200 plc from S7 300 plc on MPI Network Cpu 315-2dp Cpu 224XP i use SFC 67 and SFC 68 for...
4,472
Hello all in this forum, as you can see I'm new here this is my first post. So here it goes: I want to know if someone has done this before...
1,857
Original system was PV300 and ML1000. Comms is via 1761-NET-AIC. That setup has been working for 10 years or so. Connecting laptop via standard...
2,656
