micromax Member M Join Date May 2003 Location india Posts 3 May 28, 2003 #1 I would like to communicate with Simens S7300, S7400 using Visual Basic. I want to know any other possiblity except OPC to communicate the same.
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,324 May 28, 2003 #2 There is Prodave MPI from Siemens. This is a dll type library, I don't know if it will work with VB. B-plus makes an activeX library for € 2500. Deltalogic makes ACCON AG-Link S7. This is a dll type library, stated to work with VB. MHJ software makes an MPI driver dll library, stated to work with VB. this should give you something to get started with
RRobbins Lifetime Supporting Member Join Date Dec 2002 Location Richmond, VA Posts 405 May 30, 2003 #3 Here is a "Native" TCP connection and the source for VB that will allow you to communicate to a CP343-1 or CP443-1 ethernet processor. It works quite well. I use it for demos and it will work over the internet. It's a free-be, knock yourself out.
