Communication between Schneider 140 NOC 771 01 and PowerFlex 755 over Ethernet/IP
lalitvedak
Dec 2012
UAE
I want to establish communication communication between Schneider 140 NOC 771 01 and PowerFlex 755 over Ethernet/IP. If anybody have tried this please explain the the steps.
I have done this connection with a PowerFlex drive over EtherNet/IP. I don't recall the actual drive model, but I can check after the new year. It was not straight forward - the EDS file did not work and the drive actually used the 4-byte run/idle header (usually only the scanner/PLC uses this).
Do you have an updated EDS file from Rockwell? If so, add it to the DTM config in Unity and add the device. Set the options - EDS file dependent - like data sizes and RPI that you want, then finally the IP address.
This is a rough outline - exactly what isn't clear when setting this up? The user manual has some stuff, and I can provide screenshots to steps that are troublesome. Anyway, get started and let us know where you get stuck.
I am trying to setup communications between an m580 and a compactlogix plc. I have confirmed my set up on schneider side is correct and now I am...
3,017
hello everyone we work on a water station using plc schneider M340 and we should make a communication with a dcs honeywell , this dcs should read...
1,311
Hello, i need some help!! i connected both via rs-485 by lan cable. HMI PLC RJ-45 Mini Din 8 pin pin4 A <---> pin1 A pin5...
2,018
Hi Guys, I have a Beckhoff CP6607. It has 2 ethernet ports, 2 usb ports, and a serial port. I am trying to connect it to a Scheider VSD, an...
3,986
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
41
