Communication Cable Catalog or configuration for Allen Bradely PLC5/30
manojdhapola
Apr 2010
New Delhi
Hi All,
Plz. send me detail of Communication Cable Catalog or configuration for Allen Bradely PLC5/30.
Manoj Kumar Dhapola
Maintenance Engineer
Tecumseh India Pvt.Ltd.(INDIA)
Cont.No.: +91 9899838492
hi mickey ,
Just I have a DG application here in our running plant using PLC 5/30 .Presently here when breakdown come in DG section nobody check the ladder or online problem just he guess.so i have new joining here. i have worked in allen-bradely system so i was want to the configuration of the PLC5/30 communication cable because this PLC is very old But i think logix is same as RS Logix 500.
hi mickey ,
Whats "DG"? (Distributed Generation? )
Did you get connected?
Ya DG means Distributed Generation. no now i get not connect because yesterday was holiday in india because yesterday was here indipendent day.so i will try today.
Manoj
hi mickey ,
Even if you get the right cable, you will not be able to connect to the PLC 5/30 using RSLogix 500. You will need RSLogix 5 to upload/download or program any PLC-5.
Does anyone know what software the IDEC FA-2J Controller uses? And what cable is needed to communicate? I can barely find any information on this...
1,133
Hello guys, I need to change the configuration on an C200HW-PRM21 PROFIBUS-DP Master Unit and looking communication cable. Any one knows where...
1,217
Hello everyone, From experience which is better for field use, 90 deg or straight and why? I a inclined to buy the straight one but started...
2,113
hi i know that it require wire gaure 18 but i just want to know is that posible to use eternet wire as a io communication wire. (because it cheap...
1,438
Hello gents, Is the communication cable for the Lenze 8400 a USB to RS485? And if so can I use the Schneider one? Thanks Kal
2,321
