Mircologix communication cable, 90Deg or striaght?
kalabdel
Feb 2015
Ontario
1,108
Hello everyone,
From experience which is better for field use, 90 deg or straight and why? I a inclined to buy the straight one but started wondering if there's something I'm missing as I understand the original Rockwell cable is 90deg
With the 90 deg end you can plug in the cable and shut the door that covers the Mini Din port. It gives a nicer installation if you are going to leave the cable in place all the time. If you are only going to use the cable for programming and then you will remove it the straight cable is actually easier to plug in and remove.
That's my take anyway.
I like the straight but I sell about 4 to 1 on the 90 deg versions
Is there something wrong with your site? I've been trying to check out with times I added to the cart and have tried two different browsers but the checkout button simply doesn't work!
I managed to checkout. Don't ask me how, I have no idea but I opened three browsers, regular and private modes and kept clicking till it worked. It literally took more the 40 minutes to checkout with items that I had already selected a few days ago. You really need to fix your site.
Thanks for the quick reply and the usual awesome/quick service.
Now you really put the fear into me cause that could only mean one thing...VIRUS. Thankfully it's not my work unit but problematic nonetheless.
Not all the time.... I did update the website this AM so hopefully it took care of any issues, a lot of the time if you change one thing it screws up the website, then you need to try and remember what was the one thing you changed
Also thank you for the order!
Thanks a lot. By the way I meant that my laptop had the virus; was not implying your site, in case my comment was misunderstood.
Very much appreciated. Always a pleasure dealing with you.
Cheers
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
110
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
374
Please suggest me plc software for simulation (micrologix 500) or any plc simulator
1,887
Can anyone please help me out with a Mircologix 1400. I'm trying to configure it to send email and think I've got it figured out. However, I don't...
3,251
Has anyone converted a Mircologix 1500 to Ethernet, I see that one can use the Allen Bradley 1761-NET-ENI converter. I'm open to suggestions and...
3,273
