Communication failure
I hope you've done the obvious - like:
Check your PLC is running.
Check your cables are connected both ends and not damaged.
What were you doing when it failed?
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I have a b&r 2010 PLC unit connected to B&R IPC 5000. Communication between the PLC and IPC is failing as the two LEDs on the application...
1,038
Hi, I am using P&F - WCS reader to read position of a trolley motion on a crane. Sometimes there is Ethernet communication failure error given by...
1,049
Hello everyone, I have a GE IC695 CPE305 PLC with 3 remote panels. I am using ethernet to communicate with an IC695 PNC001 (in the main panel)...
2,678
Hello All, I need urgent help please if you do not mind. I have a project that contains the following : - one CPU S7-314 - one CP 343-1 - Four...
2,392
