communication modbus
man64
May 2017
santodomingo
Hi I have a situation with a plc 1100 to be able to read it with modbus a meter shark I want to configure the input to plc and I can not and the command to read.i have windos 10 in my pc
I am a beginner in that world
http://www.electroind.com/pdf/Shark_New/E145701_for%20web.pdf
I am assuming that you have the above equipment.
This is either using Modbus ASCII or Modbus RTU. These are both serial communications but can be confusing because the Shark has a RJ45 connector.(Modbus TCP)
Here is a link to tell the difference:
http://www.simplymodbus.ca/ASCII.htm
This site has some good information on the Modbus protocol:
http://www.simplymodbus.ca/index.html
It would help to know what exact models of equipment you are working on. Please also include what you have programmed (parameters) so far and what result you are getting. This will help in assisting you.
Regards,
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
91
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
172
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
198
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
153
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
906
