Communication problem S7-1200 / Proface
camilleai
Dec 2012
Isère
Hi everyone,
I have an HMI Proface (AGP 330-T1-D24). I try to establish communication with my PLC S7-1200 (programmed by TIA Portal)but an error appears:
" Error has been respondes for device read command (there are out of range devices)".
After tests with the technical staff of Proface, the problem would be on TIA Portal.
Are somebody here know a solution, please?
(** Please don't take care about my english mistakes. I hope my problem is understandable. **)
Thank you :nodi:.
I would guess that you are trying to read an address on the PLC that doesn't exist. Check on the HMI which addresses you are trying to read, make sure that they all exist on the PLC. If in doubt start very simple with a new HMI project and just one or two values.
Thanks.
Yes I tryed to create a simple HMI just with one value but it doesn't work.
On my HMI screen, some buttons appears but not all.
Not sure what you mean here, if you only have two values then why would there be buttons.
If it doesn't work with two values then I would think that you are looking for a wrong setting on the HMI or PLC. What IP address and subnet mask have you used for the PLC and HMI also the slot and rack number.
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,660
Can Anybody Help Me????? My problem is I need to know the pin out of a comms lead so that I can communicate to a Micrologix 1200 via an AIC+...
1,644
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
199
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
204
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,634
